Library Release Notes - January 2026
Hey Tulipians :tulip:
The latest Library update just dropped, and we’re starting 2026 with something fresh: Table Kits.
Not apps. Not connectors. Think of them as the data groundwork you’d normally spend hours building. Except now you don’t have to. And with the new Table Comparison App, you can see exactly what you’re importing before you commit. No surprises.
Six kits. Six use cases. One goal: get you building faster.
  • Quality Dashboard Kit
  • Production Starter Kit
  • Inventory Management Kit
  • Quality Kit
  • Production Management Kit
  • Material Traceability Kit
  • Table Comparison App
Whether you’re launching a pilot or scaling up, these kits give you a running start. Less reinventing the wheel. More time for the stuff that actually matters.
:backhand_index_pointing_right: Explore them in the Library
I’ve tried to import a few of these from the library but getting error: “Error: Job failed: Metadata not found [Error].”
Instance on r355
Hi Jordan,
Thanks for flagging this. I’ve reached out to our engineers and they’re looking into it.
Hi Jordan, this has been fixed. Thank you again for flagging this to us.
I’m getting the same error when i try to add this app: Tulip Common Data Model Base Kit
Also what tool is this you’re using?
Hey Jordan,
It should be all sorted now. When you get a chance, could you please confirm whether the issue is still occurring?
Cheers,
Gábor
It works now, but there are some erros/issues within the apps.
For example: Station Table ( Tulip Common Data Model Base Kit)
After creating the test data with the two stations, the status can’t be filtered, because thte dropdown list is still empty
justmy2cents
Chris
Hey Jordan,
It’s a web app we built that’s been iframed on the website!
