Load Record Link via CSV
Is it possible to load a table column that is a record link type via CSV import? I’ve tried several formats for the data in the field ("[“1”]", [“1”], [1], “1”, 1) and while none of them cause an error during the import setup or analysis the field is always empty after the import completes.
Hey @Lance ,
It’s currently not possible to import a CSV to a table that contains a Linked Table Record Column, and populate data in that column.
This is something our Product Team is aware of, and will eventually be placed on our Product Roadmap.
I can’t yet estimate when you can expect to see this feature, but I will update this thread as that changes.
Kailey
hello team,
we are just facing a situation where this feature will be helpful, do we have any update ?
oh, and also to fill a user field type
Hi @Beth
is there any updates to that topic?
I have the same issue to manually type hundress of numbers, because I didn’t find a way to upload a csv with those link data…
edit:
I found that request as well:
Import CSV with “link” - Product Suggestions - Tulip Community
