Hello,
Currently, the Machine Status widget color is tied only to the machine signal. This limits flexibility in scenarios where machine states are managed via triggers. For example, when a machine is idle and a downtime reason is selected through a trigger, it is not possible to apply custom color coding to reflect that status in the widget. Is it possible to enable color configuration in the Machine Status widget based on triggers or downtime reasons, not only on machine signals. This would allow clearer visual communication of machine states.
Thanks for consideration
