When Automations is out of beta and Tulip begins charging for its usage, I would be interested in methods to reduce the number of times it is triggered. As it I would want more options in the Event Details panel to limit a bit more without needed to use a Decision action within the automation.
The one example I have now is to add a Limit to Specific Field(s) option to Table Record Updated events so I can choose what fields in a table I’m specifically interested in watching. If a different fields value in the table is updated, I wouldn’t want the automation to trigger. This would be optional of course so someone could trigger an automation any time any field is updated.
