Hello team!
Linking machines attributes’ data sources from an OPC-UA server (IP21 Aspentech) it is very hard to search for the correct connection if you have hundreds of tags, because we don’t have a search bar. Can we add it?
Another suggestion is to add the tag ID next to the tag name, so we can reference the link in the attribute black box to data source tags. At the moment we cannot check if the link is correct. Adding the ID info in tag name can be useful also for the search, as we have seen that tags are ordered by ID.
Thank you for your support
Gabriele
