Picture widget with option to lock the aspect ratio
Hi there,
I wish there will come an option to lock the picture size of a loaded picture to the preset size.
If the loaded picture size doesn’t correspond with both widget sizes, the picture aspect ratio will be used to fit the size inside the widget with the given limit size. So all pictures will look correct without any distortions if the picture size doesn’t match exactly with the widget size .
It’s a little bit like the option “reset aspect ratio” if you insert a picture
Is it possible to realize?
Regards Chris
Same question as before: is it possible to include this feature?
Regards Chris
Hey Chris,
This is a great suggestion! This request would fall into the changes to make to the app editor widgets in the second half of the year. Please continue to vote or create new product suggestions though, your input helps us prioritize the widgets we start with.
Best,
Yuji
