Platform Release 316 - April 2025
:tada: Exciting news - Release 316 is here!
Share your thoughts and questions below :arrow_down: :blush:
Hello @jaksif.
If I’m not mistaken, the new Ctrl shortcut to disable snapping was not added to the Keyboard Shortcuts popup in the app editor?
Some great Community product suggestions included in this release!
From @ChrisF - Editor: Move objects without alignment
From @nicolettenaya Duplicate Condition in Conditional Formatting for Interactive Tables
Thanks y’all for the great feedback and enjoy the new features!
@fti - it looks like you’re correct on that one. I flagged to the team to add that shortcut popup in app editor :slight_smile:
I have question on this one.
Deprecation Notice
  • Changes the behaviour and text of expression deprecation warnings. Now, if an operator clicks on the text of the warning, it will be muted for 7 days. Note that this mute applies per-operator and per station. If the operator changes, or the same operator uses a new device, the notification will re-appear until it is muted again.
What is “expression deprecation warnings”, and why is it muted “per-operator and per station” ?
I believe it should also consider “per trigger action” so that we can be aware of all deprecated expressions.
hi @ta-aoki , we got some feedback that Operators wanted to be able to mute these warning notifications. We made them mutable on a per-User/Station basis so that every tester of an application or new deployment would be able to catch these issues with triggers, that are effectively runtime warnings and errors like invalid DateTime, or Divide By Zero.
Yes, these are per-Trigger-Action, allowing you to have the best visibility into which triggers and expressions should be updated to ensure great data quality.
Thank you for catching this and asking great questions - as always.
