Release 220 - January 2022
These are the product updates in release 220 of the Tulip platform.
Release 220 will be live to all production customers the week of 1/3/2022.
Improvements and Bug Fixes:
  • Keyboards are now supported for popup modals (escape key to exit, enter key submits)
  • The design of toggle sliders has been updated
  • Popup modals have had design improvements
  • Created, updated, renamed, and deleted activity for Machines and Machine Types will appear in the Activity Log
  • Machine analytics can be imported and exported with apps
  • Transition runtime is enabled by default for new apps (will not affect existing apps)
  • Fixed Firefox’s “find in page” popup when typing / or ‘ in the Expression Editor
  • Master-layout elements will not show over form steps when printing
  • Expression editor will not conflict with app editor cut and paste actions
  • Triggers will not clear machine activity fields
  • Context pane widget increment and decrement buttons have been added to the border radius in the App Editor
  • The default color for variables with no color selected has been updated to be transparent gray
  • An optional label field has been added to the SAML page
  • Updated optional labels on the user profile page
  • The Create Station and Station Group popup modal has been updated
  • Machine Data Source save button for OPC UA connectors has been fixed
  • OPC UA connectors will not add a gray image if no image is set by the user
  • Tooltip examples for the MID and FIND functions in the Expression Editor have been fixed
  • The Variable Date Picker in the App Editor will not be cut off by other UI elements
  • Long words in the App Editor will not be cut off by other UI elements
Hello Tulip team,
Could you explain “Transition runtime is enabled by default for new apps (will not affect existing apps)” ?
Thanks by advance, Patxi
Hi Patxi,
This change affected a small number of legacy users, updating their accounts to be in line with the current UI of the platform. Users affected by this were notified of the change.
