Release 213 - August 2021
These are the product updates in release 213 of the Tulip platform.
Release 213 will be available for some customers on 08/30/2021 and will be live to all production customers the following week.
Tulip API Improvements and Bug Fixes:
  • Trailing whitespace is trimmed when creating table record IDs
  • Queries endpoint supports “updatedAt” and “createdAt” filters
  • The “runAggregation” endpoint can use “updatedAt” and “createdAt” filters in the Tables API
  • The machine archive POST endpoint has been fixed
Machine Monitoring Improvements and Bug Fixes:
  • Image upload for machine data sources has been fixed
  • Re-adding machine activity fields that have been removed does not result in an error
  • Bug allowing file types in machine activity fields has been removed
  • Connector Host maintains a connection to OPC UA server when a single request times out
  • Editing restored machine type triggers does not modify the published version
  • Updating machine types does not fail without reason
  • Editing state is consistent when switching tabs on the machine page
  • View and edit machine type modes have similar spacing on the screen
More Improvements and Bug Fixes:
  • Dashboard analyses only run when visible
  • “View table charts” wording has been updated to “View table analyses”
  • Expression errors show as expressions are edited
  • Dragging and dropping apps and app groups to the root level has been fixed
  • Invalid variable values will not prevent completions from being recorded
  • 17 new actions will appear in the recent activity feed
  • If no company logo has been set, a broken image does not appear
  • CSV imports to Tulip Tables create audit log entries
  • The “createdAt” and “updatedAt” columns can be used in filters with Table Queries
  • Ellipses for long aggregation names added to prevent content from being cut off
  • Station Operator, App Approver, and App Builder roles have been added
  • Number input widgets have consistent behavior with separators across different languages
Tulip Player 1.2.2 updates:
  • Added a Vision-based barcode detector in Player
  • In Vision, Snapshots can capture regions with the “Take snapshot for regions” device function
  • Onscreen touch keyboards always open with Windows touch devices
  • Content occlusion handling has been improved when the onscreen touch keyboard is open
Great news as always :slight_smile: Could you add the new user roles in the knowledge base (in the summary of roles) ? Thanks by advance
