Editor: Move objects without alignment
if you have a lot of objects on a step, it’s very difficult to move/position an object with the mouse without aligning to unwanted others.
So please add the possibility to move an object without aligning to other object, f.e. with an addition key pressed (ALT+move).
Chris
Hi Chris,
Thanks for the suggestion here! This is a good callout and the team is looking into it.
Happy Friday @ChrisF - this has been implemented in Platform Release 316 - April 2025 :tada:
You now have ability to temporarily disable widget snapping in the App editor while holding the Control key during drag operations.
Hope this helps :slight_smile: Let us know if you have any additional feedback on this feature
