It would be nice to lock the movement axis when rearranging elements on a step similarly to how photoshop allows you to move only along the X or Y axis if Shift is held.
Sometimes I want to adjust the Y axis of multiple elements without it attempting to snap to other elements along the X axis, and while you can just hold the up or down arrow key, this method is much slower than being able to click and drag it along an axis.
Ah, I see. It appears that snapping is overriding the axis lock. When I have a lot of elements relatively close together or elements near the edge of the screen I am still getting movement on both axes.
For example: I have an element whose starting value is 2 on the X axis. If I hold shift and drag down, it is locking to Y movement, but only after snapping left as well and moving to 0 on the X axis. I have a lot of variables displayed, so when I move one of those elements on the Y or X axis, it is still snapping to page edges, midpoints, and the edges of other elements on screen.
That makes complete sense Richard - thank you for testing! This will likely be solved with upcoming improvements to snapping in coming months. I’ll aim to send you a quick update to let you know when that has launched.
