Platform Release 322 - June 2025
:tada: Exciting news - Release 322 is here!
Share your thoughts and questions below :arrow_down: :blush:
Really cool stuff!! Happy to see these features coming to the platform. This will certainly make the life of my fellow colleagues much easier.
Really a fantastic idea to enable AI in Tulip!
Great improvements, but it looks like the diagrams work only for smaller apps… with big ones, the screen is blank.
@jacek.kos Could you DM me the link to that app and we’ll investigate?
The diagram is the beginning of a dream/request I had from 4 years ago! :heart_eyes:
That said, due to the size/complexity of an app we have, 300% isn’t enough… :see_no_evil_monkey:
Love this though; going to unlock a lot of great new features! :raising_hands: Thanks!
First of all, thank you for the many great new features :slightly_smiling_face:
I tried to use the new AI-powered trigger summary feature, but I can’t find it in the trigger editor or in the Tulip AI settings (platform version r322.2). I also checked on another instance and found the same behavior.
Are there any specific requirements or a rollout schedule that I need to consider?
Hey @pwied -
Just looked into this - it looks like this will just be rolling out in two phases, the first customers got this feature with r322, and the second group (your instances) will get this feature with r233 (rolling out to your sites is planned for the night of the 17th).
@klickal We’ve tweaked the rendering for large diagrams, take another look in r324
Great, thanks @mglidden!
The button is here now, but it does not work @Pete_Hartnett
We are experiencing the same issue. I’ve tired the diagrams feature with over 10 applications and none of the larger applications were able to generate diagrams.
r324 will have two fixes for app diagrams:
  • All diagrams will now start at the same level of zoom, creating better visibility on large apps
  • Fixed a crash on diagrams of apps that had step transitions on step open triggers. @nicolettenaya I suspect this is your issue, if you want to DM me the link to that app, I can confirm that it’ll be fixed.
r325 will have another fix for apps that have double quotes in the app or trigger name.
@pwied -
Thanks for reporting this - it is tied to some hosting differences with your site - we have fixed in r325.
@jaksif Any word on when r324 release notes will be posted? It’s been deployed for 3 days now
@jjj sorry for the delay, release notes are now out for Release 324, check out here. :slightly_smiling_face:
@Pete_Hartnett
Unfortunately, the AI-generated trigger description still does not work—error message as above.
Hi @pwied just saw this - is the AI-generated trigger description feature working for you? If not, what’s the error you’re still seeing?
Hi @OlgaStroilova, thanks for asking. It’s working now :blush:
Unfortunately, it’s only in English, but I’ve already created a product suggestion for this: Multilingual AI-based trigger description - Product Suggestions - Tulip Community
Thank you on both confirming things are working and logging the product suggestion! Totally understand the internationalization value - we keep an eye on upvotes to help with prioritization.
