Exciting news - Release 331 is here!
Share your thoughts and questions below
Is the broken reference going to be automaticallly fixed when published?
PLAT-46129 Fixed a bug where apps with broken connector function references could not be published.
Good News…
When will this come for Single- and Multi-Selects?
I wonder, why this is done one by one …
Hi @thorsten.langner great question. Implementing this improvement has to be carried out one by one in how the inputs are structured, so we’re rolling them out iteratively in order of priority to customers. We feather this in to the other sprint work we have, and also balance with the other “Quick Win” improvements we’re working on.
Yes our hope is to also implement for single and multi selects. We don’t have an exact timeline yet, but hopefully we’ll be able to fit this in soon.
Hi @ta-aoki ,
We’re unable to fix the broken reference because the connector function it points to was deleted, and we don’t know which function should replace it. Similar to other trigger errors (for example, when a machine is deleted), you’ll see an error message when running the application in development mode or in the player. To resolve the bug, you can identify the correct connector function to use in place of the deleted one, then update the reference.
Since we were unable to archive the used connector functions from r303, I thought all the connector functions used in the App cannot be deleted. Maybe I am not understanding these release notes correctly. Could you please explain?
Connector functions can now only be archived if they are not used by any apps or automations.
Hi @ta-aoki,
A couple of clarifications:
Hope this clarifies,
Cana
Hi @ta-aoki,
This is a feature mainly for life sciences customers who need to have an installation certificate for the processes. In addition, it’s transparency behind the installation process for our customers.
Sincerely,
Jake
In Player, a warning will be shown if a user attempts to close Player while triggers are still executing.
Does this apply to Windows Tulip Player and iPad Tulip Player ?
I tried to see the warning, but it did not appear.
(I closed the Player when repeated email sending action was still running.)
Hello
Long-running Triggers notification is really helpful for operator but also useful for apps builder team to point performance issue on their application, they could start some investigation with target system integration, review SQL query or rebuild some logic in the apps to improve the user experience.
Today to catch this information, we need to ask to all operator to send us a print-screen with this notification message.
Did you plan a feature to display this information (long-running trigger) at platform/workspace level? In the meantime does support team could extract log on this long-running trigger notification?
Thanks
