Release 199 - January 2021
These are the product updates in release 199.
Release 199 goes live to all production customers on 1/17/2021.
Features
  • “Text” response type and outputs are available in Connectors
  • Timestamps are supported in HTTP Connectors
  • Error messaging for Connectors is more descriptive
  • Boolean input widget can connect to a table
  • Added OAuth 2.0 customization
  • Users can now launch a specific app directly from the player URL
Fixes
  • The run button opens the correct app in Player
  • Default Working Days update correctly in account settings
  • Signature Form signatures are always recorded when an app is canceled
  • Machine Monitoring widget uses the proper timezone to calculate intervals
  • Removed unnecessary copy/cut/paste buttons
  • Date picker in Player is rendered correctly
  • Improvements to loading times for the expression editor
  • “Cancelled” message does not show when printing
  • Error messages in dev mode display in the same place
  • Shared dashboard links are visible in Incognito tabs
  • Analytics editor does not crash on Tulip Tables when the second column can’t be part of an analysis
" * Users can now launch a specific app directly from the player URL" Can you explain this new feature?
Hi Youri,
Using the URL format:
/player?=appID
With this, you can open Player directly to a specific app. The appID can be found with the app editor open.
AppID URL:
/groups/DEfQiXSMmpyyoYEqF/processes/z5h3XaxL6aG7GFJei/versions/BifP5EBxGETLoGvLn/steps/q8oE8AoDsHZDWGdDm
The AppID is the string of characters between processs/__________/versions.
Let me know if you have any more questions!
this feature is what I were looking for. and Gio promised the feature would be released . great
