These are the product updates in release 208.
Release 208 will be available for some customers on 06/02/2021 and will be live to all production customers on 06/06/2021.
Improvements and Bug Fixes:
- Updated Tulip logo and favicon
- Camera widget works without variables
- Exporting CSV table analyses functions properly
- Players should no longer show a white screen if the internet disconnects
- Machine state change app triggers work for machine variables
- “Any Attribute” machine triggers ignore State Change Events
- Tables API allows dropping of all record for tables with links
- Vertical scrolling on shareable dashboards behaves properly
- Logging out in GxP mode does not trigger a failed attempt to report a completion
- Created records from the Tulip API no longer show as deleted users in the Record History Widget
