Potential Bug/Issue or New Method to store arrays from connector outputs
Hey Tulip,
Today I noticed the different behavior with the connectors than usual, and wanted to share with the team for further evaluation.
Ideal Situation:
If I run a connector function with multi-row output then → when I store the result system should store as a list when I create a new variable.
Current Behavior:
When I’m running a connector function and trying to store the data by creating a new variable → system is creating variable with is not a list. → Due to this trigger action is failing.
Work around → After creating a new variable I go to → App → Edit Variables and change that variable to list → then trigger action is working as intended.
Let me know if you need more information on this.
Thanks.
Hi @jay.shah,
Thank you for the input, I have informed our engineering team and we are working to fix it!
