Print Steps to physical printer with varying results
I’m having issues with printing to physical letter. I have my app setup on Letter Portrait and all steps are set to “Use App Resolution”. Each time I print I’m getting different results, sometimes the printout is perfect, sometimes its cut in half. I’m not sure what could be causing this. I’m using the same printer with the same settings. Does having the app full screen vs. minimized impact the printing?
Hey Brandon,
The app being full screen vs minimized should not impact the printing.
How are you printing your app? Are you using the “Print Using System Dialogue” button in your app to print?
Kailey
