Hi teams, i create the region configuration for the vision color detection, but it could not work for two regions at the same time. We need to detect the two regions in one picture through using color detection. thanks!
Hi @Emily, thanks for using Vision! Just going by the image that you’ve posted, you can use let’s say “Skin Color Detector” of type color detector, and set the color value accordingly. You can then enable the same detector for multiple regions. If you’re building an app to verify if both the regions detect the color, you can use the “regionName” output from the “color detection began” event to check this condition. Also, can you please attach a screenshot of the region configuration tab for both the regions so that I can better assist you with your issue?
