Vision OCR region
Just wondering when the new detectors for vision will be released?
I’ve got a project where we’d like to use googles OCR to capture a serial code off a device label. I think it will be difficult without a region definer since there’s more than just a serial number on the label.
Thanks!!
@DewyWCI hi!
You can start using the Google Vision APIs right away to perform OCR with Tulip Vision Snapshot.
However we are going to be officially releasing additional Vision features in the very near future that may make it easier and faster.
If you would like to get an early trial to access beta features, please contact our support team or the Vision team.
Thanks for the help Roy! :+1:
Hey @DewyWCI,
You should now have access to these beta features!
Thanks Het for enabling these! Cant wait to try them out!
