These are the product updates in release 189.
Release 189 goes live to all “production” customers on 8/2/2020.
Two major upgrades to Interactive Tables in apps
Interactive Tables now support arrays of objects from HTTP connectors and multi-row output from SQL connectors (finally!)
Also, you can now fire trigger logic when an operator selects any row in an Interactive Table.
Assign tasks to Operators by embedding the User Table
Add a list of users that match a certain condition to a step in an app, and then fire Trigger logic whenever an operator selects one of the choices
Other Releases
- Use the new “gear” icon on the “Step” tab of the Context Pane to remove all master widgets from an individual step.
- We have improved the syntax for adding multiple filters when querying the Tables API
