Removing an existing link from a record
I cant find any documentation on how to use Table Record-Unlink record.
I also cant get it to work.
@daman.sahota, thanks for the post, and this is a good observation.
I’m going to pass this to our documentation team to make sure this gets covered. In the meantime, can you share more about your trigger so we can help you figure out where the snag is?
same problem here. could we share any info?
btw, found that video a good one, but it doesn’t cover how to remote the links Quick tips - Linking records - YouTube
Just run into this table unlink record issue. Has anyone got this working?
Do you try to unlink by API or by App Trigger?
API: Unlink records - Tulip Tables
Trigger:
What did you try? And where did you struggle? Can you be more precise, what the issue is?
I used the app trigger.
I was stuck at the ID to Link. could not find any documentation on what information to insert there
ID to link is the Record ID of the Table Record you want to link to that placeholder record.
This must have a field that is set as a linked field to the selected one at “field”.
Thank You. This solved my query
