As an app builder for GMP applications I sometimes come across applications that require use of the electronic signature widget.
I have a problem figuring out how to reset the electronic signature widget after execution, the only solution I’ve managed to implement is reset with help of “Complete App” action but that action resets my variables to default.
Is there an alternative that you’ve came across?
