Retrive data to update record (like SQL JOIN)
Hello,
I have an application where i need to fill table column with data from another table.
Here an example:
Table A
ID
Column A
Column B
Table B
ID
Column B
Column C
I need to search in Table B using a non ID field (Column B) that is present in both table. In the end i have to copy Column C into Column A
How can i do it inside a trigger?
Thanks
Take a look at the knowledge base article for modifying tables: How To Modify Tables Within the App Editor | Tulip Knowledge Base - Support for Building Operations Apps
I think what you’re looking for is under “Loading Existing Records” if I understand your case correctly. Especially the section on using a variable in a trigger.
