Rich text editing is new for R234 and is useful for:
- Formatting lots of text
- Formatting multiple text elements like a Header and Body in one text box
To apply formatting, highlight the text you want to change and it will appear in the text editor widget on the right side panel.
You can highlight text for formatting in a text box on the canvas, or in the text editor on the right panel.
Selecting text will show the currently applied formatting. Changes to text formatting are reflected simultaneously in the text editor and on the canvas.
Text that is the same color as the editor background will show up faintly or not at all.
