Scheduled deployment
Are we able to create forced scheduled deployment and log the user out and restart the app?
or
Any work around?
Thanks!
Hey @Leooh0411, can you describe i a little more detail what functionality you’d like to see? Do you mean you’d like to schedule when new versions of apps go out in advance, and automatically log any users out using the old version?
Hi @Leooh0411,
If @John’s assumption is right, then please use the existing Product suggestion and add your vote.
You can also post your comment or question in this thread to push it again.
Scheduled app publish - Product suggestions - Tulip Community
This thread can then be closed.
