Hello Guys,
Is it possible for you to consider adding a functionality that allow us to share variables between different apps? Here is a link for the technical topic : Global variables - #3 by FahdERM
@FahdERM you can achieve this functionality simply by using Tulip Tables, which can be shared across apps and also be used for analytics!
These are good places to start:
Hi @royshilkrot,
This is what i am doing right now but the only annoying thing with tables is that i have to know by advance the ID of the record to use.
