Shortcut Feedback
Hello.
In the app editor, this shortcut is Cmd + Shift + Z, but in the Automations editor it is different. Should standardize. Either is fine.
Also, in Automations you can ctrl + scroll to zoom in and out. Which is GREAT! This is pretty standard for drag-and-drop web apps. In the app editor, you cannot do this (yet).
@danielpomeranz thanks for the feedback! @kimberly I know you are working on standardizing things across the design already - but figured I would flag this for you
