Single select of colors shows RGB values
Hello,
I have a table that one of the fields is by color type, I have to add above the table a dropdown widget (Single select) to make filter on the table by color value.
So, I added a single select widget, created a color variable, added values of colors.
When running on the player, the user can see a dropdown widget but the values are not the colors themself but the RGB values of the colors :
So, my question is very obvious, how can I let the user to see colors instead of RGB values ?
And, will I be able to filter table using a query by this color value ?
Thank you,
Amit Berku
Hey @Amit, you can switch the input to a Single Select text option like below, then add a trigger on the input widget that uses IF/ELSE logic to set the color variable based on the text input. If you really want the colors to be visible, you can use emojis, but options are limited.
As a Workaround you could pick from an Interactive Table:
Will this ever be fixed?
Actually I need the color dropdown too, but as long as the interactive table still can’t handle colors (for filtering, sorting), this function is useless :frowning:
Chris
