the spacing of the label fields in the widgets are fix and independent from the font size.
Please change it to a smaller value (percent of the font size f.e.) or make it configurable
Regards Chris
Regards Chris
Hi @ChrisF,
I understand your point about the fixed spacing being independent of the font size. I see how this might limit customization options within your app.
I can suggest an alternative solution that might help achieve the look you’re going for. Consider using the Text widget instead of the Label widget.
The Text widget offers more flexibility in terms of customization, including font size, positioning, and styling. This might give you more control over the appearance of your labels and better match your desired design scheme.
Appreciate the feedback. If you have any further questions or suggestions, please don’t hesitate to reach out!
Adam
that’s because I tagged it as “Product suggestion” ![]()
Regards Chris
