Appreciate the added label text field to input widgets to remove the need to add a separate text widget for the label. For my apps, with many tables and input fields, the real estate available for these widges is limited to make sure it does not appear too congested. When changing the font size of the input text and the label text to a smaller size, the fonts will change but the gap between the label box and the input box remains the same. It would create some empty area in my app if the spacing could change either dynamincally based on font size chosen or user adjustable. This is specially useful when designing an app to run on a smart phone and not on a computer screen.
Related topics
| Topic | Replies | Views | Activity | |
| Spacing of label fields in widgets | 2 | 127 | February 14, 2024 | |
| Auto adjust the font size of text to fit Text Box boundaries | 1 | 339 | February 1, 2022 | |
| Autosizing Font Option for Widgets | 2 | 82 | July 14, 2025 | |
| BUG: Widget height inconsistent if labels are used | 6 | 228 | October 8, 2024 | |
| Large Text Box Font Size Display Issues on iOS | 4 | 486 | June 28, 2023 |
