Instead of going from one step to another step, as per user case, All steps should be should in a single step something like Routing in Angular Js or React Js where the header and footer are constant and the middle (Body) changes as per the click !!
hello @psp316r, thanks for posting!!
could you share a little more on the use case you’re building?? there are effective ways of replicating this with Table Records, and dynamically loading the information from a single step.
this app in the Library can be used for reference if you’d like to take a look at how it can be used: Dynamic Work Instructions | Frontline Operations Platform.
looking forward to hearing form you.
