I created an automation that would fire every time a record is added to a given table. I get the records information and then create a new record in another table with some of that same record information. However, when I tried this the ID and record are created in the new table but nothing addition is stored from the original record. I’ve attached the automation, any help would be great!
Thank you!!
https://plugpower-staging.tulip.co/w/1/automation/3ovLMb8SvRTjoXG9M/version/dev
Hi @thiggins,
I took a peek at the automation attached and tested it out. I added a record to the table that triggered the automation and it properly added the information to the other table.
More than happy to sync with you on this. Also, only members of the Tulip Team would be able to view your automation so it may be helpful to provide the context of what you’re trying to accomplish or reach out to us at automations@tulip.co with any questions.
Sincerely,
Jake
