Suggestino about Current step input validity
Hello Tulip team:
It will be convenient if the text input or other controllers in Current step input validity can be displayed as their Labels. With this feature we can easily identify which controllers we are using
Hi @yuhuan.pu
I’m sorry but I strongly disagree!
Every Input Widget has a Name, but not every input widget has a Label.
I Actually avoid Labels, since I don’t like the style options (distance and position).
Simply name your widgets correctly and it is easy to manage:
This also helps in keeping track of your widgets, layering and tab order…
Thanks thorsten. I strongly agress with your suggestion. Change the name of the controller can solve my problem
