Translate text and save in variable
Hello,
Can anyone help me with translating static texts and storing them into variable part.
Thanks
Suparna
Hi @suparna.dey - I think this article should provide what you are looking for to be able to use triggers to translate text and store the result in a variable!
https://support.tulip.co/docs/translate
Let us know if this helps!
Also, note that the trigger that does this is now called “Frontline Copilot” and not “AI (experimental)”
Thank you very much Beth. This is what I really want to know.
Unfortunately, in the Tulip instance where I am currently working don’t have this Trigger Action. Can you explain me why, and how to get this feature.
Thanks & regards,
Suparna
Gotcha.
Is this on your instance or a customer instance you are working on?
I ask because Copilot is available on all Tulip plans, but there are some instances that are deployed in environments (what we call “gardens”) that do not have access to the AI models that Copilot uses. In these environments, copilot triggers will not be shown in the product.
Copilot is not available in environments / gardens that are on Gov Cloud, in China, or Tulip Customer Cloud (TCC).
Hi Beth,
I am working on customer instance. I believe this one is TCC instance, but not sure.
Anyway, thank you for your help.
Thanks & Regards,
Suparna
