Hi, I try to set Triggers for Button “Begin” so I leave the IF command blank and choose Go To Step command for for THEN but it does not accept it. Pls. advise.
Ishmael
hello @ishmaelg, we can certainly help out with this!!
can you select a specific step within your app (or Next) in the dropdown to the right of Go To Step?? for example:
Thanks Gio. It worked. Can you also help me with the “Home” button (left bottom corner) which was created as new edited Button. Which Commands do I use to get to the start of the App.?
Thanks
hello @ishmaelg, for that you can seelct: App, followed by Complete App And Go To Splash Screen.
for example:
Thanks Gio. It is OK now.
