Tulip Player 2.0.0 - Jan 2023
These are the product updates in release 2.0.0 of the Tulip Player .
Contact support@tulip.co with any questions.
Tulip Player 2.0.0 will be available on Jan 11, 2023 from 9 PM.
This release involves:
  • Significant under the hood overhaul that upgrades the rendering engine to Chromium 108 along with stability improvements and bug fixes.
  • Improved session contention handling across Windows user accounts.
  • Multilingual support for Zebra network printer driver.
  • Support for Dymo 50 KG Scale.
  • QWERTZ keyboard layout support for Insize depth calipers.
  • Fix player identity not in sync across Windows accounts when global data is cleared.
  • Fix barcode scanning case mismatch.
  • Fix closing of device drivers when closing Player.
  • Fix bug where IP cameras were losing stream even after reconnecting.
  • Fix bug where one failing IP Camera config would fail all other camera configurations.
  • Add retry mechanism for setting up Realsense camera pipeline.
  • Add the ability to run device function and ask vision to record a video, upload it and return the URL.
  • Add support for using Realsense cameras with different resolutions.
  • Add support for running ONNX models on the vision process.
  • Vision OCR - improve robustness and performance.
  • Change the OS detection scheme for determining whether Vision should run.
  • Add capability to run anomaly localization models on Player.
  • Add support for 4/5k resolution for Allied Vision Camera.
  • Fix bug where vision model download failed due to protocol error.
