If you have auto-updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
We plan to release a trigger that will allow you to take a screenshot of your screen. We needed to make changes on the player-side first to allow the trigger-side changes to happen.
The functionality should be released in the next few weeks!
Hi Team,
I’m trying to download the v2.7.2 MSI installer, but the download link on this page (Tulip Player Enterprise Deployments) still points to version v2.7.1.
As per our deployment requirements, we do not use auto-updates. Could you please provide the MSI installer for v2.7.2 or update the link on the page?
