Version 2.7.0 of Desktop Player is available for as of December 28th, 2024)! If you have auto-updates enabled, the Desktop Player application will update in the background and changes will take effect the next time the application is restarted. Alternatively, you can manually initiate the update process from the file menu.
Hello Jake,
A bit confuse, 2.7.0 is a major release but I don’t notice any change on Windows player.
We agree that this “major” release didn’t impact Windows player user?
We are waiting a key feature on Player to allow to add and manage custom driver on Player.
Did you have any visibility? I thought that it was plan Q1 2025.
Hi @Nicolas,
This release didn’t impact windows players. We plan to have an additional release of Player for LTS14 that should contain the infrastructure of custom drivers.
Sincerely,
Jake
