Updating Tulip tables with Node Red - 2 questions
I am using node red to integrate our AMR fleet with Tulip being the interface for mission control. I have connected tulip to MFE software and a send calls for missions. In order to get the JSON message from MFE back to Tulip I had to use a middleware. I have chosen Node Red (since it is already available on our Edge IOs). There are multiple pickup and drop off locations/stands throughout the plant). What i am trying to do is receive a call in node red from the fleet software to keep the status of these stands up to date. Once i get this call I know what stand and what status it should be.
First question, one column in my tulip table is color format. I have tried to pass the message below with the hex code but i get error 422 back. Any thoughts on what i need to send to update the color in the table?
msg.body = {‘yjxyj_status’:‘Not Available’,
‘wpgvf_stand_color’:‘#C33D36’}
return msg;
Second question, in the tulip table node… for the record ID i want to use a payload to determine what record to update. Should this work?
I got the command structure to update the color object data type:
msg.body = {
"wpgvf_stand_color": {
"r": 62,
"g": 126,
"b": 232,
"a": 1
return msg;
