If a variable is not marked clear on completion, how long is the variable kept?
Until someone signs out?
Hey @daman.sahota, thanks for the question—it’s a good one!
If a variable is not marked “clear on completion,” it will be populated until the app is cancelled, which can happen from Menu > Restart, navigating away from the app, or if you’re using GXP features, then logging out.
Let me know if this answers your question.
