Write to Machine's PLC
Hello guys,
Is there any way to write data from Tulip to Machines’ PLCs.
NB : Actually i am using Kepserver (OPC UA) to get data from the machines API so can i do the same thing but in the other way (from tulip to machine’s PLC using kepserver or an other way).
thanks,
Yes with Kepware gateway that can expose OPC UA write method in REST protocol.
@youri.regnaud is the only option to pass string data from Tulip to PLC to either use Kepware or Node Red? Is it possible to perform a hard wired connection from Edge IO to the PLC and write the data to the PLC?
I need to pass a recipe from Tulip to the PLC but the PLC is currently not on our network.
