Hi @gio,
Got to Know from the chat support there is option to write from the Tulip to KepSerEx using Nodred, Is there any article or any ticket where there is process to do this ?
Shashi
Hi @gio,
Shashi
If you use Kepware Gateway, you can write new tag value with an Tulip HTTP connector connected to Kepware gateway.
Hi @youri.regnaud ,
Thanks for the quick response, is there any example or article or can you explain how to do, which helps to move forward with the suggestion ?
Shashi
