I am trying to send a signal to one of my machine in shopfloor. All the machines are connected to Kepware, so can I post a signal with HTTP connector?
Use Kepware gateway to expose OPC write tags in HTTP protocol
Thanks for your reply. So, This means I can use HTTP connectors to POST to KepWare right?
Yes, https://www.kepware.com/getattachment/c5c35697-8a91-4273-8077-b28fe5d60d8c/iot-gateway-manual.pdf We use it every day to send tare in our Mettler Toledo scale connected throught Kepware with UCON driver
Thank you very much. ![]()
IT/OT convergence needs IT/OT protocols mediation. IT protocols are well know, shopfloor is a brownfield with so many OT protocols. We need mediation and OPC UA HTTP is just a exemple
I tried sending my signal over HTTP it works thanks alot.
