An option to reset a single variable to its default value
This is a nice to have.
An option to reset a single variable to its default value.
data manipulation - deafult value
The user case is to reset an input form and only reset the variables used in that particular step. We may not want to reset all the variables in the app.
Hey @Rakitha -
Great idea. I could totally see how this could be a challenge to work around (I’m not entirely sure how I would approach it, but at a minimum, it would be annoying).
I wrote a req for this one. Super easy change for us to make, its just a matter of getting some resources allocated!
I also like this idea.
I suggested this one in November 2019 as well.
So maybe it doesn’t sound new to someone in your team.
Some of my ideas are already implemented, but I’m still missing this one. So I’m happy to read it here.
Hi!
Is there any updates on this possible implementation? It would come really handy on various of the apps we use.
Hi @gdiaz! Welcome to the Tulip Community :tada:
This one has be in the queue for a while, so the team is looking to see if we can get it scheduled to be worked on. Stay tuned!
