Analysis Operation Order
In a Tulip Table Analysis, there seems to be no way to change the “Operations” order. For example, I am using the “Universal” template and have 6 Operations which are all complex expressions (the Operation order directly corresponds to the column order in the table). I would like to add another Operation expression, but have it show as the third column, but there is no way change the Operations order, and thus, the column order without deleting and readding them all. I confirmed this was the case with our Tulip representative.
It would be super useful to be able to change this order with a hamburger button so I don’t have to delete and redo all of my expressions just to change the order - thank you!
