Barcode Format widget
currently you are providing only 128 format on widget barcode. This format is thoughly limited by the maximum of characters (55 exactly)
I recommend you to focus on more complex barcode such as datamatrix or Qr code
where the maximun of characters is more than 1’000 (for both).
Barcode Suggestion
Hi Mathieu, this would definitely make more sense. However, the current package that we use for this does not allow for QR code or Datamatrix, so we would need to replace the package entirely. This would make it a medium-sized project.
What is the use case you had in mind for displaying these barcodes on the screen?
