I just received feedback from a user on adding a flash option for the camera. We have some areas that have lower lit areas that when using the embedded camera, the quality doesn’t come out as clear.
Great idea! thanks for sharing. we’ll certainly look into it and will keep you posted as there are updates.
I am interested in this feature as well, is it anywhere on the feature timeline?
Just got this request today from an operator.
The new upload feature in the camera widget allows you to upload photos from your photo library on your device, so you should be able to simply use whatever native camera app there is on the device, use the flash, and upload the picture into Tulip that way.
