Using mobile device Camera App to take high resolution and focused pictures
Hi all. Reshef from Tulip here.
Wanted to share with you a quick solution to take better images with your Mobile Tulip Apps.
The Tulip embedded camera widget is limited in resolution and will not allow you to focus the image by tapping the screen.
To overcome this try the following:
  • When creating the mobile app, select the Image Input Widget Phot input options to be Camera or file upload. (attached screenshot)
  • This will allow the user to upload a file from the phone/tablet instead of using the camera from the Tulip App.
  • When clicking the Upload button, the mobile device will ask if you want to upload a photo from the Photo Library or Take Photo.
  • Choose to Take Photo will send you to the mobile device camera app.
  • Focus the image, take the picture and approve to go back to Tulip and use the focus picture. (this will also allow you to save images with higher resolution than what the Tulip app allows.
Text extraction on this app done with Tulip AI Triggers. If you want to try it for Labels Verification or any other text extraction from pictures/documents feel free to reach out.
Hi Reshef,
For projects where integrating a variety of different devices might be a larger undertaking I was thinking about taking a picture of test device display (imagine pH/conductivity meter, filter integrity tester, potentially gauges or old school test devices with no possibility of integration) and just use the picture and extracted data for documentation and result evaluation.
Would the Tulip AI Triggers fit this use case?
thx
asger
Hi
Sorry for the delay in response. I was OoO for a few weeks.
That could work great.
I’ll be happy to have a short call to try it. If you can gather some examples we can test it together.
We can send me your availability this week to reshef.gadot@tulip.co
Tnx
Reshef
