I’m not sure if this is a bug or a feature request, but right now on our iPad’s (latest model iPad’s and iPad mini’s) touch to focus with the camera inside of Tulip does not work. Is this something that could be enabled?
Hi Ethan-
Thanks for the feedback! That sounds simple enough, we will take a look and consider it for future work.
The new upload feature on the camera widget works well for this. On iOS/iPadOS if you select upload, then choose “Take Picture” you have access to touch to focus. That works for our needs, so I think this thread could be closed?
Hi @Ethan, glad to hear it is working for you, thanks for following up!
Hi @pete I think a focus option for when you’re trying to scan barcodes with a camera would be helpful.
