Hi @sumeet.sabat, if I understand your question correctly, I don’t think it’s possible to use the camera embedded in your mobile phone with Tulip vision. I’d like to get a second opinion from @Reshef.Gadot in case this isn’t the case. Please also let me know if I’ve mischaracterized your question.
Hi @sumeet.sabat ,
Currently it is not possible to use Vision Camera configuration on a mobile device.
Some of the applications such as snapshots, barcodes readings and OCR (via a connector function) can be used with the Camera Input Widget.
Are you building a specific application for mobile devices?
Hi Sumeet. I’m just in the process of writing an article for our knowledge base on how to use connectors for OCR with Tulip.
I’ll be happy to get on a quick call with you and show you what we got.
